gbyleveldt
·Ok, not quite dumpster finds but they were "cheap" for a reason.
The Aquaracer is full of DNA and has lived a hard life. It got chucked in a drawer after the original owner got told by the local TAG AD that he will need a complete new bracelet for $500 and he had to commit to a full service for $800 as it was in "desperate need based on the condition". It had to be sent to Switzerland because they don't service chrono's at the local AD. As you can see it's only one of the removable links that broke and I managed to find two spare ones. Some of the pin and tubes in the non removable links are also on their last legs, so I'll probably end up having to strip all the links and service the whole bracelet in the end. Which is gonna suck as they're incredibly difficult to take apart. I'll obviously service the movement as it runs and stops.
The Link is actually pretty cool as it's Chronometer Certified using an ETA2892A2. This wasn't a very common choice for the "cheap" Link range (I say "cheap" many times but it should be taken in context of what good examples sell for used. None of these were Seiko cheap). It's missing the bracelet (which will stay missing I'm afraid) and the crown threads are stripped. It also looks a little rough but at least it runs, so I'll be polishing it up a bit and service the movement.
Lastly is the Carrera I showed elsewhere. As later pics will show it appears to have a scratched up crystal and there's internal debris under it. The bezel insert also has two dings. It sorta runs but stops after a little while. I grabbed this one as it came with all the extra bracelet links, papers, box, etc. I've already ordered the original crystal, bezel insert and gaskets as in the pic.
For now I'll be tackling the Carrera as that's the one I like the most.
