TAG Heuer Connected E2 Modular 45 not working stuck
  1. i.l13
    i.l13 Jul 1, 2020
    Tag Heuer Connected 45
    Stuck on boot logo - not going past TAG boot screen.
    Please if anyone could help
    Edited Jul 1, 2020
  2. BMW Works
    BMW Works Jul 1, 2020
    Try a hard reset through recovery menu
  3. i.l13
    i.l13 Jul 2, 2020
    dont have a recovery menu on my watch - could you provide that?
  4. BMW Works
    BMW Works Jul 2, 2020
    Restart watch or hold 15 seconds button pressed.. While showing tag heuer logo or intel logo swipe from upper left to bottom right while holding button pressed.
  5. i.l13
    i.l13 Jul 3, 2020
    i know this method , but the watch doesnt have a recovery installed on it.
    Would you be able to provide that from your watch?
  6. i.l13
    i.l13 Jul 3, 2020
    modular 45 recovery ??!::confused2::
  7. BMW Works
    BMW Works Jul 4, 2020
    Dont know how to extract it
  8. i.l13
    i.l13 Jul 4, 2020
    Thanks for your reply. I have found this tool that extracts rom from the watch. It is very simple and easy to use. Could you try it and let me know if you could provide the rom?
    https://gofile.io/d/ZHju9S
  9. i.l13
    i.l13 Jul 15, 2020
    anyone has a link for the firmware image? this is why its a help support forums!
  10. TAG GUY
    TAG GUY Jul 15, 2020
    This isn't a support forum, it's a community forum. This is something you need to contact TH about.
    BMW Works, Albert-AMG and Anthony.R like this.
  11. i.l13
    i.l13 Jul 28, 2020
    anyone has a solution to this ? :whistling:
  12. VRman
    VRman Jul 28, 2020
    With the correct files and process(x86 based) not available to pull an img or backup you should consider sending your watch to TH and have them restore it to factory settings for you.
    BMW Works and Albert-AMG like this.
  13. i.l13
    i.l13 Jan 19, 2021
    anyone be able to fix this issue? have been trying to fix it for ages!
  14. J.C
    J.C Jan 19, 2021
    Buy new watch hard will be cheaper than sending to TH seevis
  15. TOÑO MJ
    TOÑO MJ Feb 3, 2023
    hello
    i have the same problem with my tag haver conect need dowload firware and flash need help please
