Hi, I am new to the forum. Wanted to ask all your opinions please. i have a Tag 2000 model WK1120-0 a two tone gold and steel. i would like to know if this is a mens model size or a womens as i cant seem to find any info around. Many Thanks
@automobilia42 is correct You can see here how to decode the standard model codes: http://forums.calibre11.com/threads/tag-heuer-model-codes.18513/
Hi Thanks for the reply. I happened to see the same watch with this model number WK1120-1. So i would like to know what is the difference between WK1120-0 and WK1120-1 Appreciate your help
Same watch basically. The "-01" is used when there is a minor update in parts- for example, with the Monaco Calibre 17 a few years back they slightly moved the position of the holes in the lugs so that a bracelet could be fitted
Thanks for the info. As i thought the WK1120-0 was mid size as it seemed a bit on the small side, and was wondering if there was a larger size for this model.
