Tag Connected 45 Strap
Hi
Just purchased a Tag Heuer Connected 45 and was wondering if anyone knows if there is a shorter strap available? I have adjusted the strap as far as it can go and it the watch is still a bit on the loose side.
Thanks!
Hi and welcome!
When the TAG Heuer Connected Modular 45 was launched, the straps were too long for most of the wrists, and this problem was later solved by TH with shorter straps (but keeping the same reference number). When the watch was bought new to the AD, TAG Heuer offered free replacement for these too long straps, but I don’t know if you have bought it new or second hand.
So, if you buy additional straps online, be sure that you are going to receive the updated size and not the first version: the shortest half of the strap measures 9.5cm in the old version, and 7.5cm in the updated version. Ask this size to the seller before buying it, to be sure.
Hi and welcome!
Thank You
Looks like the band measures about 4” which is close to the 9.5CM. It appears that I have the longer band
Yes, for sure you have the older/longer strap version. If you bought the watch in a TAG Heuer AD, you can ask them the replacement of the strap for free.
Otherwise, if you can’t get the free replacement (I would go to an AD to ask for it) the solution to save your current strap is connecting the buckle directly to the strap, removing the link of the buckle. But then it will be not so quick to release from the strap...
If you have plans to buy more straps but not more buckles, then it’s better to keep the link on the buckle and don’t use again (or change) this long strap as soon as you have the updated/shorter straps
Does anyone know if the straps that Tag Heuer currently sells on line (for the 45) are of the newer/shorter version?
Thank you
Thank you
It should be the shorter version, because it’s the newer version, but it’s better that you ask for the shorter version when you order it (and/or ask the seller for the size of the straps that you are going to receive), because both versions have same part number, so the only way to identify the version is measuring the straps
