Blue Tag
·Does PVD Coating last a long time before
Peeling or cracking ?
Are you looking at any specific watch? Because I think it differs a lot between watches depending on shape of the case, material of the case and pricepoint of the watch (cheaper watches seem to have crappier coating). One thing worth remembering though is that if you are worried about this and think that it would bother you it is probably better to look into other materials if you want a black watch e.g a carbon, ceramic or composit case that will be scratch proof and remain black because a coated case will eventually start loosing the coating.
Yes , I was looking at aquracer and tissot?
All in black ...
I'm with Jim on this one. PVD looks cool and is scratch resistant - not it is not impervious to scratches. If a scratch does happen and you can see the steel underneath the PVD coating, this cannot be corrected or polished out. The entire part (e.g. bezel, case, bracelet, etc.) would need to be replaced.
A few years ago, I managed to put a nasty ding in my F1 chronogrraph bezel. It's a long story, but I was in a confined area and managed to hit my watch against a concrete pillar. Amazingly, the crystal was not scratched. But the PVD coating on the bezel had a few deep scratches which I covered with a black jiffy marker. It looked OK, and I was probably the only one who noticed the flaw. But it bothered me. Eventually, I bit the bullet and ordered a new OEM bezel. It wasn't that expensive, surprisingly, and there's a local TAG Heuer Service Centre in my city so I took it there where they swapped the bezel on site.
My point is - something will likely happen eventually. If you're OK with scratches, then I'd say go for it. If you are OCD like some of us, then maybe think about a watch with a different material or coating.
Good luck!
Do they make solid black watch cases
I can only really comment on more vintage pieces (1980s) in which case we see a lot of wear on PVD coating, not necessarily from bumps and bruises but merely rubbing against body parts/clothing etc. (they're all on brass cases btw.)
Not sure if the process has been improved since, either in the material or application (I guess it has) however isn't/hasn't DLC pretty much taken over from PVD or are they still using it?
Steve
Steve
Omega has a black ceramic planet ocean.
Pvd apparently depends on the harness of the material it is on, hence most (all?) recent TH pvd watches have titanium cases.
I've worn a black aquaracer 500m for about 4 years, on and off, I've been fairly careful but not obsessive and I've traveled with it a bunch of times. So far I've not managed to scratch it, but there is a tiny amount of polishing on some of the corners. I've posted pictures here previously when we have discussed pvd.
From watching youtube videos, carbon bezels are to be avoided. Apparently AP made a Royal Oak with a carbon bezel and when they inevitably go back they replace them with a ceramic bezel because the carbon is useless.
The seller said "nobody really cares about discontinue Tag".
Well, let's suffer such ignorant fools gladly! 😉
On completely different track, now the discontinue carbon version of RO AP considered as "collector's item"
I went to sell my Heuer01(to a watch seller) the other day and said, they are discontinuing the Heuer01. The seller said "nobody really cares about discontinue Tag".
Expected. But i am still butt hurt.
I think a common mistake is to confuse these terms, if I remember correctly DLC is a type of PVD. PVD is the process and DLC refers to the type of material used or something like that
The 1980s pieces are steel not titanium, the coating may have improved too
