Heuer 2000 Quarz Chronograph 262.006
The Chronograph is from the early 80 th before TAG was involved. Im searching a replacement movement, the watch has a problem with the E-block.
The original Movement is an Eta 555.232.
In a couple of posts I read that the movement was replaced by a Eta 955.112, I guess this was for the non Chronograph model. Maybe somebody can help me and let me know which Movement i can use and is still available
I can't help I'm afraid but I do really like this piece!!
Pretty sure what you actually have is a Calibre 185 movement, which is a combination of an ESA 555.232 base quartz module (i.e. time only) with a mechanical dubois-depraz chronograph module. The ETA equivalent to your base module is ETA 955.232
NY
Is it possible to just replace the circuit board without replacing the complete movement?
