Battery for E4 42mm lasts only for 12 hours
I just bought new E4 42mm and I love it. However, the battery lasts only for 12 hours and maximum of 14 hours; is this normal?. I tried to turnoff the always screen on option however that did not help.
I did reset again and the battery did not improve.
Give it at least 3 to 4 charging cycles.
Mine lasts a full day always.
Thanks for the reply. It has been 2 weeks now. I went to the shop and they replaced it with new one. Will give it couple of days.
By the way, I am using an android phone (pixel 8 pro) I am not sure if this causes a battery drainage.
M Meshal
If anything using an Android phone should probably give you a better battery life, not worse, because Android phones are better optimized for Wear OS watches like the TAG Heuer Connected. I have a Connected E4 45mm and a Pixel 7 Pro and I always have over 50% battery when I take it off in the evening. The 42mm does have a smaller battery, but it's also true that smartwatch battery life can vary wildly depending on lifestyle.
Thanks for the response. It seem that the issue was with the old watch. The replacement has now way better battery performance, 5 hours since full charge and it is now 83%.
M Meshal
This sounds roughly consistent with my experience. Glad you have your problem solved.
Thanks a lot.. The watch battery now last for about 20 hours
try the following:
Routine 1
From time to time when charging, if you feel that battery life is bad.
Put watch in cradle
Press powerbutton continously for about 30 seconds. Watch will reload approx 3x
Charge over night without removin from cradle
Routine 2
Charge watch over night
Take out of cradle and switch off, then switch on
Let it outside cradle for approx 4-5 min
Put in cradle again and wait until its charged 100%
Both routines for me work in a significant way. Whenever I feel battery getting week (approx every 7 days) do one of these and enjoy 14-16hrs with AOD Display
Hope it helps
I have had the Tag Heuer Connected calibre e4 42mm for just over a year. I absolutely love the watch. Had similar battery issues. Not lasting more than 12 hrs. Tag Heuer replaced my watch one time asked me to do a factory reset another time and finally again asked me to send the watch back to check.
I have done this now battery lasts more than 24 hours for me.
1. Reset the watch
2. Connect as normal to Tag Heuer app.
3. Now log out from Tag Heuer phone app.
4. Install Wear OS and connect through Wear OS, Tag Heuer app will also connect automatically.
Will show Watch connected and Wear OS. Attached pic.
Work for me dramatically improved battery life. Hope this helps.
1. Reset the watch
Hi Francisco,
thanks for that infos. COuld you define "dramatically improved battery". Wre we talkng about some % or a significant number, like >20%?
THanks and kind regards
Luca
Hi Francisco,
Luca
Hi Luca, my watch battery lasted 12 to 14 hrs. max. previously, now lasts about 30 hrs. if that helps.
Regards,
Just received my E4 a couple of weeks ago and the battery is flat before lunch every day. I've factory reset and turned off the always on display. I've also just got a basic TAG Cosmic watch face now but the battery life seems terrible. I'm assuming it's a faulty unit?
