Does anyone know if there is an index of crowns used on 1960s and 70s Autavia models I have a a few watches and the more I look at similar models the more complicated it seems to get. For example I have researched crowns fitted to 3646 Second case third execution and the dimensions on watches quoted range from 6.4mm wide 2.5mm deep 6.5mm wide 3.4mm deep 5mm wide 4mm deep I understand that back in the day Heure were using a range of parts so do we just accept these anomalies as something that adds to the Heuer individuality or have a resource that can confirm that often used phrase “all original” is indeed true. I suppose the bigger question is. If you love the way your Autavia looks, does it really matter? Any thoughts or guidance gratefully received
Giving this a bump. I'm on a journey to get a 3rd execution 3646 and have also seen a range of crowns, including unsigned similar to the Carrera. Is that possible? A crown database would be invaluable.
