Monaco CAW2114 (“black and red”) - is it an UFO?
Greetings,
A more or less lucky owner of a Carrera Cal.16 (CV2011), this is my first post on this forum. So apologies if I am violating any untold etiquette...
Also apologies for my question as such, but I really spent some time researching around reference CAW2114 (including on this platform), but w/o much success.
EDIT: Did eventually find the nickname “Black McQueen” (but that's about it): https://www.calibre11.com/tag-heuer-monaco-range/
The CAW2114 (= the Monaco Cal.12 variant with a black dial, but with more red accents then its sunray blue sibling) seems to be from the early- to mid-2010s (I checked the PDF catalogues uploaded here, but didn't find it) and technically no different from the blue Cal.12. What I am wondering is:
1 - given its relative scarcity, was that a limited production run (of any kind)?
2 - does the dial have a flat or a sunray finish?
3 - does the black dial make the Monaco “wear (visually) smaller” - as is often the case with black dials?
Tks in advance & happy confined Sunday 😀
Give Google Images a shot, maybe you can find some "in the metal" wrist photos from owners or reviewers. I don't recall this being a limited edition, but the Monacos don't always sell well in colorways other than the classic blue, so they may have stopped making it after a short run.
As for visual size, in my experience the sides of the case around the dial are thick enough to negate any difference in visual size. It's a large watch, but not so much that it feels too large.
Hi! I also researched on it before. I’ve read an article calling it the “Black McQueen” I think it is not a limited edition. Yes the Blue Dial Calibre11 Monaco is really the more popular due to SMQ & pedigree. And probably only a few can appreciate the black dial one (no sunray effect). After getting a Steve McQueen Monaco (CAW211P), i decided i wanted to get a different Monaco which is a bit modern, has the classic looks with a different calibre movement, but also keeping it distinct (black dial) yet still unmistakably a Monaco! Similarities are the size 39mm, square case, panda & automatic. Differences would be Calibre 11 x Calibre 12 (crown pusher placement), blue dial x black dial, Heuer x TAG Heuer logo. There are a few other black dial Monacos around. The two ACM versions, the French Edition Calibre11, the Bamford verison, and also one/two of the 50th Anniversarry are in black dials. HTH sir 👍
Side by side with my TH Carrera 1887 43mm 😉
Hi- and welcome aboard.
No, not a limited run, but part of the core collection. I think your other questions have been covered off- I like this one, and think it looks great on the rubber strap. Good luck 👍
Tks guys. All of this is really helpful 📖
Waiting for a potential seller's answers to decide if I should pull the trigger...
Yes - it’s not the typical SMQ livery, but I think it easily holds its own compared to the “classical” blue Monaco Cal.12 thanks to the additional splashes of red. Also, I somehow feel that the Cal.12-typical circular arrangement of the indices works particularly well on the flat black dial.
Tks again, guys - inching closer to the buy (just a couple more weeks).
I was just wondering whether anyone has some experience with the replacement straps for Monacos from WatchStrapWorld in the UK. I know them from my Carrera (in 20/18mm) and quite like their quality and price point.
So I imagine that they are probably just as good in 22/18mm for the Monaco... (?)
I have one that is fine. It probably measures 21.5mm across so there is a tiny bit of 'play' at the lugs but nothing to worry about.
Tks. I think a quarter mm of “play” is quite acceptable given the price requested... 😉
Picked mine up yesterday! Definitely a nice variant and all I hoped it would be. The watch is clearly not a safe queen but has been worn and loved on a fairly regular basis - but the price took that into account... So overall very happy with my purchase 👍
(NB: “Lag” of minute hand vs. small seconds is about 30sec - so pretty much as expected for a modular chrono and easy to adjust for.)
I even still found a relatively well matching (Hirsch “Performance”) 22mm strap in my strap box:
The only thing I just found out, and which saddens my a little bit, is that even with a relatively high-grade modular chronograph (with vertical clutch), such as the Monaco, starting/stopping the chrono DOES make the main minute hand “jump” a little...
I have seen that in the past with Valjoux/Cal.16 chronos, but I have also seen that some brands modifying their ebauche movements succeed in suppressing this effect.
Black McQueen 😎😎😎
Congrats sir! Very timely! 😉
