Hi Today I am also proud owner of this watch. I have only a small wrist so the metal closer is a bit on the left side of my wrist and makes problems on the skin. Is there a possibility that there are bracelets in different sizes? If yes the metal closer is more in the middle and this would help... Check pics
The strap is adjustable, but not the one you see in the photo with the outer clasp.. only the 'bottom' strap is adjustable. So if your wrist size is small the clasp will be skewed closer to you as pictured.
It looks like your bracelet is backwards. Maybe try it the other way and see if it's more comfortable. Otherwise, there's also the metal bracelet and you can have the jeweler remove links from each side, so the clasp stays in the middle. ETA: I take that back. The strap is oriented correctly. But my clasp has the Tag Heuer writing flipped around.
