Normally it couldn't do any harm as far as I can see it, but you will need a special tool for the caseback to remove, otherwise scratches on it are most likely. And if it does run, it will be probably full with old oil/ grease that has gone bad and is now like as hard as chewing gum, so the chance it is running fine is most likely not that high.
I would leave it alone, keep it closed, advertise in the state it is in complete with all the possible items you have with it (extra links, box, receipts etc.) make excellent pictures and a good description, the buyer can then do whatever they want with it.
I would conservatively value it in this condition at around USD 450-500 because of its nice outside N.O.S. condition.
See it as a great opportunity for a watch-collector to repair or for parts.
But running and serviced at least USD 750+.
Hope the info helps.
